Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to apply a tabular node-temperature in Mechanical Apdl › Reply To: How to apply a tabular node-temperature in Mechanical Apdl
August 5, 2024 at 3:45 pm
In this case, the *dim command would be *dim,yyyy,Table,110000,,,NODE The primary variable NODE indicates that column zero of the table (column 1 of your csv file) are node numbers. Then as Mike says, you input the table array by entering it in quotes: BF,ALL,TEMP,%yyyy%
