Ansys Learning Forum Forums Discuss Simulation Fluids Calculate mass flow in a specific area Reply To: Calculate mass flow in a specific area
Rhandy Delefortrie
Thank you! I managed to create the necessary surface by imprinting the top surface of the vial and decided to create a custom field function to calculate the mass flow rate by using the density, vertical velocity and surface area. However, as I'm only interested in the amount that goes inside I can't find how to define only the velocity that goes down inside the vial.Â
