Ansys Learning Forum Forums Discuss Simulation Photonics scattering calculation with gaussian beam in FDTD Reply To: scattering calculation with gaussian beam in FDTD
Guilin Sun
Scattering parameters use plane wave by definition. So when you use non-plane wave, you have to decide what quantity to use for the intensity, since abs(E)^2 is space-dependent. You may use the peak intensity, or an averaged intensity, it is up to you.
wrinkles? it might be due to reflection from PML, or source size is small. Here is what I got:
