Ansys Learning Forum Forums Installation and Licensing Ansys Products Unusual Bug for .deb File Conversion Reply To: Unusual Bug for .deb File Conversion
Lito
You are welcom. If you are running from the command line directly, you will not see the "Running state with the time remaining..." right away since the simulation will initialize, mesh do other calculations before running the actual simulation job. I will be closing this post.Â
