Ansys Learning Forum Forums Discuss Simulation General Mechanical Why stress and strain do not change with time Reply To: Why stress and strain do not change with time
Armin
Thanks Jin. I think the source of stress concentration is the hole. To verify, you can run a model without the hole to compare the results. You can also make a trial run with bonded contact behavior to evaluate the results for a case when all regions of the screw surface are contributing to load transfer.
