Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › how to set up to find the pretention force of the bolted joint › Reply To: how to set up to find the pretention force of the bolted joint
August 2, 2024 at 12:50 pm
Thank you. What you are saying is that the bolt pretention is the reaction force corresponding to the boundary condition. So if I apply a moment to a surface of a bolt, is the reaction force in the axial direction on that surface the preload force corresponding to that torque?
