Ansys Learning Forum Forums Discuss Simulation General Mechanical Importing Boundary Conditions from INP File Reply To: Importing Boundary Conditions from INP File
mjmiddle
You should do your own research on Abaqus commands. Here is one location I found:
https://classes.engineering.wustl.edu/2009/spring/mase5513/abaqus/docs/v6.6/books/key/default.htm?startat=ch14abk15.html
The follow defines an nset in Abaqus:
*NSET, NSET=unloaded_seg_Mesh-1.131073
  1466, 1467, 1468, 1469, 1470, 1471,
The numbers are node numbers.
You should also be able to define the nset during the *node command as you have done, but it looks wrong to repeat the *node command 3 times with different nset names before the node ID and coordinate lines.
