Ansys Learning Forum Forums Discuss Simulation Fluids Modelling low viscous liquid (water) flow on a viscoelastic porous material Reply To: Modelling low viscous liquid (water) flow on a viscoelastic porous material
I think you'll need Fluent coupled to Mechanical depending on how complex the membrane motion/behaviour is. However, without knowing what result you need from the model it's near impossible to point you at anything other than the core learning materials (Learning on here) to allow you to build a basic knowledge of what can be done.Â
