Ansys Learning Forum › Forums › Discuss Simulation › Electronics › How to conduct temperature variant EM simulations in HFSS ? › Reply To: How to conduct temperature variant EM simulations in HFSS ?
July 31, 2024 at 7:40 am
Hi Jalaj,
Thank you for reaching out to the Ansys learning forum. Your patience is much appreciated.
Did you go through "Setting the Temperature of Objects" section of the HFSS help document available through the Help menu.
After setting the temperature dependence you need to run a parametric for temperature to see the effect.
Best regards,
Praneeth.
