Ansys Learning Forum Forums Discuss Simulation General Mechanical Importing Boundary Conditions from INP File Reply To: Importing Boundary Conditions from INP File
mjmiddle
Your nset name is clearly missing the rest of the names you used in the *boundary command.
You nset name is "unloaded_seg_Mesh."
Your first 3 boundary commands use "unloaded_seg_Mesh-1.131073" and the number at the end changes for other lines.
