Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Volume Fraction too Low. How to Improve? › Reply To: Volume Fraction too Low. How to Improve?
Hi,Â
below is the inlet BC.
Below is the outlet BC.
For side wall temperature: as temperature was fixed at 273.15K . you can see the volume fraction and temperature in below screenshot. even at tubewall_vapordomain, the volume fraction is too low but saturation temperature is 300K.
Point to note:
1- after some iterations, my pressure inlet outlet values become same which is 968150Pa. as per setting this is outlet pressure and inlet pressure is 1061700Pa. i don't understand why.
2—In multiple simulations, sometimes mass flow remains the same or shows a minor change at the outlet. Sometimes, mass flow at the outlet increases drastically, but in this case, mass flow is not changing.Â
3—As you suggested, I have turned off the fixed temperature from the cell zone and want to apply convection at the near-wall BC. Are you suggesting that I put a temperature value at the Tubewall_vapordomain interface or at tubewall1, which is the innermost wall of the tube?Â
