July 30, 2024 at 5:37 am
Jeone
Before the fatigue analysis, I will do static analysis with 1 N unit load, however as you see, there is 9.6N in the loads. nCode will multiply 9.6 with 1N stress result, so nonlineer situation will not effect. In this way, I want to do 1N, 2N, 3N...9N static analysis. I want nCode to do the following. Take the 9.6N load from the 9N static analysis or use the result of 10N if it is closer to it. Like interpolation. I hope, I could tell it.
