Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Question about streamline(velocity or velocity of stn frame) › Reply To: Question about streamline(velocity or velocity of stn frame)
July 29, 2024 at 3:09 pm
Thank you!
So if I set the variable to "velocity," the color setting should correspond to "velocity."
Conversely, if I set the variable to "velocity of stationary frame," I should also set the color to "velocity of stationary frame" to obtain the correct and appropriate velocity distribution.
Is my understanding correct? Thank you again for your response!
