Ansys Learning Forum Forums Discuss Simulation Fluids Gettiing problem with interacting structures have moved too far Reply To: Gettiing problem with interacting structures have moved too far
Mike Pettit
You can model the end stops with fenders, but you cannot plot (linear) RAOs of the (nonlinear) structure motions including end stops. For this, you should run a time domain analysis. Then you can plot the instantaneous structure motions of the spar and torus, as well as the Fender Forces result (Elastic Force component) which will indicate when the torus makes contact with the end stops.
Mike
