Ansys Learning Forum Forums Discuss Simulation Fluids Asymptotic convergence check Reply To: Asymptotic convergence check
SRP
User defined report definitions can also be used in the Convergence Conditions.User defined report definition functions are defined with the Define_Report_Definition_Fn macro, which takes the function name as the argument. The function must return a real value. Once written, it should be compiled and loaded the same way as other user-defined functions. With the user defined report definition function written, you must hook this function to the user defined report definition.
For more details on this macro, you can check here: 40.2. Monitoring and Reporting Solution Data (ansys.com)
