Ansys Learning Forum Forums Discuss Simulation Electronics ansys Student electronic version: ICEPAK Reply To: ansys Student electronic version: ICEPAK
alexia.carenini
Goodmorning, when I use the icepak project with steady state solution type, i select all the object to obtain the EM losses but I've the following problems when I try to use my project:
How you can see don't compare automatically the source design and the source solution.
If then i click on OK this compare:
I've also tried to obtain the source design and the source solution manually but nothing compare.
