Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Static Structural vs ACP pre › Reply To: Static Structural vs ACP pre
July 24, 2024 at 4:06 am
Ro.hi
Basically, I have two hollow tube for bending testing and their dimension is same OD=16; ID=14& L=230mm. I try to simulate the tube under two methods Static Structural and ACP pre.
In static structural, I applied material as Epoxy carbon woven (230Gpa) Wet. And I fixed one end of the tube and appling the force(9.81N) on the other end.
And, In ACP-pre i tried to appling the 5-types of layer for laminating under 0°,45°,90°,-45°,0° and the thickness is 0.2mm per layer. After all process, I share file to Static Structural path.then I follow the same instruction for previous static structural way.
