Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Different Static Pressure when reading steady result into transient case? › Reply To: Different Static Pressure when reading steady result into transient case?
July 23, 2024 at 3:10 pm
Assuming the single phase was run with water you may be able to patch a result. Moving from single to multiphase is always complex as you move from domain to phase/mixture domain and not all data has an equivalent. You can run VOF with only one phase, so set any boundary conditions to the phase of interest and ensure you fill the domain with that phase. There are some more things to consider but it generally works.Â
