Ansys Learning Forum Forums Discuss Simulation Fluids Custom module Reply To: Custom module
Vinicius Daroz
Hello Salma,
Take a look at tutorial 23, available on Ansys' help page. You will find a step-by-step guide on how to install the SDK dependencies and compile your first module. After that, you can check the available examples on Ansys' customer portal. You will find a custom drag force module, that will serve you as a good starting point.  Â
