Yannis
Hi Zhaokai,
Which version of MotorCAD are you using? Is the thermal envelop simulation crashing or taking too long to converge? If you run a thermal analysis without coupling to Lab, are you still having convergence issues? This will probably require the model to troubleshoot so please reach out through the customer portal and create a support ticket.
Kind regards,
Yannis Skourkeas
