July 21, 2024 at 5:45 pm
SneOG
Bbp_participant
I set the inlet boundary conditions to a pressure inlet with a gauge total pressure of 3,000,000 Pa and a supersonic/initial gauge pressure of 3,000,000 Pa.
I set the outlet boundary conditions to a pressure outlet with a gauge total pressure of 101,325 Pa.
I chose oxygen as the working fluid and set the density to ideal gas.
For the report, I looked at the static pressure contours and plotted an XY graph along the centerline of the nozzle. I expected to see a pressure of 3,000,000 Pa at the inlet, but the observed value was lower.
Is this enough information?
Thank you in advance.
