Ansys Learning Forum Forums Discuss Simulation Photonics Missing script content in the old post Reply To: Missing script content in the old post
Guilin Sun
Unfortunately the new Forum policy does not allow us to share the script.
Basically, the work flow is like this:
1: with the scatter, you do the simulation, make sure you use override mesh to have the TFSF uniform meshed.
2: get the E and H field components from the monitors;
3: witht the same mesh in the previous simulation, simply disable the scatter, and run the reference simulation
4: get the E and H field data
5: get the difference of the field data. and then do the integration.
The rest is to follow the script in the scattering example.
