Ansys Learning Forum › Forums › Discuss Simulation › Photonics › New Material Importing, Only Takes Integer Part › Reply To: New Material Importing, Only Takes Integer Part
July 19, 2024 at 6:41 pm
Amrita Pati
Hi Mustafa,
I tested something similar and I was able to import the data without any issue. The wavelength is not being populated as well. Are there any spaced in front of the data? The first column should be wavelength, the second should be the real part of the index, and the 3rd should be the imaginary. I am wondering there are spaces before the first column? Here's what the data I use look like:
I will recommend you to also make sure that the unit of the wavelength is correct when you import the data.
Amrita
