Ansys Learning Forum › Forums › Discuss Simulation › Electronics › coil problem › Reply To: coil problem
July 19, 2024 at 4:03 pm
It seems like you would like to keep the 10 Amp*turn MMF, then the current in 20-turn coil is 0.5 Amp per turn. In this case, you can still use 1 A current excitation, but you need to use 2 as the number of parallel branches for the 20-turn coil.
GL
