Ansys Learning Forum Forums Discuss Simulation 3D Design ansys discovery initial temperature Reply To: ansys discovery initial temperature
Devendra Badgujar
Hello Arden,
For what I understand, you are trying to set Temperature Vs Time. Such option is not possible yet.
You can define constant value for temperature on faces, and then start time depedent analysis. Specify the time duration else the analysis will go on until stopped.
Thanks,
Devendra
