Ansys Learning Forum Forums Discuss Simulation LS Dyna Acceleration in Drop Test Reply To: Acceleration in Drop Test
Armin
It depends on the drop height, material, and other factors, but locally high acceleration magnitudes in drop tests are normal in my opinion. You can also check the values reported under the "Average" column to see if they are better in line with your expectation.
