Ansys Learning Forum Forums Installation and Licensing Ansys Products unknonw error occured .. plz help me Reply To: unknonw error occured .. plz help me
Kim Sang Hoon
Hi, Thanks for your help.
I opend the .err files and I found the messeage such as
/COM,ANSYS RELEASE 2024 R1           BUILD 24.1      UP20231106       12:00:31
 *** WARNING ***                         CP =     217.641   TIME= 12:02:55
 Element shape checking is currently inactive.  Issue SHPP,ON or
 SHPP,WARN to reactivate, if desired.
 *** WARNING ***                         CP =     349.125   TIME= 12:03:55
 Material number 160 (used by element 25617130) should normally have at
 least one MP or one TB type command associated with it.  Output of
 energy by material may not be available.                                "
And I opend the .out files and I found a lot of message such as
 *** NOTE ***                            CP =    1192.281   TIME= 12:16:46
 Symmetric Deformable- deformable contact pair identified by real
 constant set 158 and contact element type 158 has been set up.  The
 companion pair has real constant set ID 159.  Both pairs should have
 the same behavior.
 MAPDL will keep the current pair and deactivate its companion pair,
 resulting in asymmetric contact.
 Pure thermal contact is activated.
 The emissivity is defined through the material property.
 Thermal convection coefficient, environment temperature, and
  heat flux are defined using the SFE command.
 Target temperature is used for convection/radiation calculation
  for near field contact.
 Small sliding logic is assumed
 Contact detection at: Gauss integration point
 Average contact surface length                1.0670
 Average contact pair depth                   0.76337
 Average target surface length                 1.6093
 Default pinball region factor PINB           0.25000
 The resulting pinball region                 0.19084
 Initial penetration/gap is excluded.
 Bonded contact (always) is defined.
 Thermal contact conductance coef. TCC         4041.3
 Heat radiation is excluded.
 Max.  Initial penetration 5.374761241E-07 was detected between contact
 element 25540342 and target element 25604619.
 constant set 159 and contact element type 158 has been set up.  The
 companion pair has real constant set ID 158.  Both pairs should have
 the same behavior.
 MAPDL will deactivate the current pair and keep its companion pair,
 Average contact surface length                1.6160
 Average contact pair depth                   0.48480
 Average target surface length                 1.0608
 The resulting pinball region                 0.12120
 Heat radiation is excluded."
And terminal messages were
: "ERROR: Worker process(es) with rank(s) 2, 3 have encountered a FATAL error.
 The information below was gathered from the file*.out output file(s).
 Please review the worker process output file(s) listed below for more
 details on this error.
 Worker Process Output File .\file2.out:
 *** FATAL ***                           CP =     111.094   TIME= 12:19:52
 This model requires more scratch space than available.  The program has
 currently allocated 12252 MB and was not able to allocate enough
 additional memory in order to proceed.  Please increase the virtual
 memory on your system and/or increase the work space memory and rerun
 the program.  Problem terminated.
 Worker Process Output File .\file3.out:
 *** FATAL ***                           CP =     111.062   TIME= 12:19:52
 currently allocated 11963 MB and was not able to allocate enough
 the program.  Problem terminated.  "
plz help me, sir..
