Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › › Reply To:
July 18, 2024 at 8:35 am
I know that using outres, the size of the output file can be reduced, but there is also an alternative method using the output controls in the Ansys analysis settings. In the Ansys analysis settings, you can find the output controls, and here you can find an option to store results using different options available.
Analysis setting < Outputcontrosl < Store results at < Choose the option
 Please check all the options. I generally use the specific recurrence rate of 5 , which stores the results for every 5 substeps(As shown in the image ). This is a very simple way of doing it, but just give it a try.
Bests,
Vamshi
