Ansys Learning Forum › Forums › Discuss Simulation › Optics › ANSYS SPEOS: how to run a simulation with an assembly › Reply To: ANSYS SPEOS: how to run a simulation with an assembly
July 18, 2024 at 8:28 am
Hello Maxime,
You can use a material created in the main scdoc, in a below scdocx.
Example :
You import in main scdocx called A, to assemblies B and C.
You can use a material created in A for surfaces of A, B and C.
You can use a material created in B only in B. Same for C.
It's the same for the sources.Â
Simulation created in A can include sources of A, B and C.Â
Simulation created in B can only include source of B.Â
Thanks
Thomas
