Ansys Learning Forum Forums Discuss Simulation 3D Design ansys discovery initial temperature Reply To: ansys discovery initial temperature
Arden Knaeblein-Greene
hey, thanks for the response!
when i use the temperature BC from a thermal analysis and i use a time dependant analysis, the BC maintains that temperature on the face. only trouble with that is I would actually just like the face to start at that temperature as an initial condition, then start cooling. for instance a 200 C temperature face while all other faces are 20 C initially to simulate the heat loss over time.
this maintains the temperature the whole time.
