Ansys Learning Forum Forums Discuss Simulation Electronics Magnetizing current is not going in negative Reply To: Magnetizing current is not going in negative
GLUO
I saw some similar cases, and usually the time constant is large, it took very long time to reach the steady state. If you can confirm it reached steady state, could you do a test run with a linear core material and see if the current is correct?
GL
