Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Substep does not converge eventough criteria are met › Reply To: Substep does not converge eventough criteria are met
July 17, 2024 at 1:28 pm
Can you try increasing the number of iterations? Default is 25. Issue NEQIT command under the setup and increase the number of equilibrium iterations to say 50 or 100.
Ashish Khemka
