Ansys Learning Forum Forums Discuss Simulation Fluids What is the difference between Fluent and LS-DYNA Reply To: What is the difference between Fluent and LS-DYNA
Fluent can be made to couple with EM fields, but it's not trivial at present (check System Coupling documentation for some information).
Do you have the plasma physics, properties and model already worked out?Â
