Ansys Learning Forum Forums Installation and Licensing Ansys Products Mesh Generating Error for geometry data obtained from micro-CT Reply To: Mesh Generating Error for geometry data obtained from micro-CT
Assuming you're trying to create a volume mesh can you check in the segmentation software that all of the volumes have a finite thickness and no surface contact within a region? I've not tried small animal, but from human scans at 0.5mm voxel resolution sinuses become very corrupted and may need manual clean up: the segmentation tools typically have some good functionality for this.Â
