Ansys Learning Forum › Forums › Discuss Simulation › Fluids › change position hinged connector › Reply To: change position hinged connector
July 16, 2024 at 5:39 pm
nhanani4
ok I can already change the position.tq.
I want ask again:
1) If I want to calculate joint force in the AQWA hydrodynamic response.
At picture A, I should key in detail data or hinge connector has the default stiffness data?
2) if I should key in the data what is the formula for hinged data?
