Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Error connecting to license server › Reply To: Error connecting to license server
Hi Randy,
Thank you for your reply. Below is the output for commands..
[root@viking-headnode linx64]# file /cm/shared/apps/ansys/v241/licensingclient/linx64/lmutil
/cm/shared/apps/ansys/v241/licensingclient/linx64/lmutil: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-lsb-x86-64.so.3, for GNU/Linux 2.6.18, stripped
[root@viking-headnode linx64]# /cm/shared/apps/ansys/v241/licensingclient/linx64/lmutil -v
-bash: /cm/shared/apps/ansys/v241/licensingclient/linx64/lmutil: No such file or directory
And below is the list of files and their permissions in the directory where "lmutil" is..
[root@viking-headnode linx64]# ls -al
total 18400
drwxr-xr-x 3 root root    112 Jul 11 11:24 .
drwxr-xr-x 3 root root    20 Nov  3  2023 ..
-rwxr-xr-x 1 root root 11414520 Nov  3  2023 ansyscl
-rwxr-xr-x 1 root root  5908688 Nov  3  2023 ansysli_util
-rwxr-xr-x 1 root root   3229 Oct 16  2023 LicensingSettings
drwxr-xr-x 4 root root   4096 Oct 16  2023 LicensingSettingsUtility
-rwxr-xr-x 1 root root  1506616 Sep 30  2023 lmutil
Thanks,
Ranga.
