Ansys Learning Forum Forums Installation and Licensing Ansys Products Running Ansys Fluent from commands Reply To: Running Ansys Fluent from commands
There's a section in the User's Guide covering launching & loading a journal. I'd tend to favour setting time step size etc in the case and where possible initialising the model. That simplifies the run journal to:
/file/rcd myfile
iterate command - check in the Fluent TUI for the exact syntax   it'll probably be /solve/iterate something
/file/wcd myfile_%t
/exit
Note the first / ensures the command is always launched from the top menu. %t appends the file with the time step.
That will run Fluent in stand alone mode, and no need to use Workbench at any point in the process.Â
