Ansys Learning Forum Forums Installation and Licensing Ansys Products Pressure Coefficient of Airfoil in Ansys Fluent Reply To: Pressure Coefficient of Airfoil in Ansys Fluent
Have a careful look in the Alphanumeric definitions in Fluent. I suspect that you've not adjusted the reference pressure, density, or area or similar. The Fluent result is likely correct for your settings (assuming convergence & mesh are good) but coefficients rely on constants that are often badly defined.Â
