Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Large Assembly Bolted Joints › Reply To: Large Assembly Bolted Joints
July 12, 2024 at 4:24 pm
Ashish Khemka
Hi Dustin,
One suggestion is what if you increase the beam radius - this will result in stiffer beam. Another approach may be to run a simple model and see how much difference in result you see when modeling beam and when modeling actual parts.
Ashish Khemka
