Ansys Learning Forum › Forums › Discuss Simulation › Photonics – Korean › Plane Wave Source 위치 이동 불가능한 버그 › Reply To: Plane Wave Source 위치 이동 불가능한 버그
July 11, 2024 at 7:25 pm
Guilin Sun
This source is independent or inside a group or "model"? I guess there is some script that controls the z location of the source. To verify, you can create a new project file and check if this happens again.
If there is script in analysis group or model to control its z, please check the script. If you want it to be parameterize it , you can add a new variable and similarly to set its z location. Anytime you change the variable value the source location will be changed.
