Ansys Learning Forum Forums Discuss Simulation Fluids Serpentine cooling channel battery pack simulation temperature problem Reply To: Serpentine cooling channel battery pack simulation temperature problem
You can have a solid-solid interface but the better option would be to connect the zones. Look at share topology in SpaceClaim or Discovery (depending on where you built the geometry).Â
