Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Monitor doesn’t record the full data in EME › Reply To: Monitor doesn’t record the full data in EME
July 9, 2024 at 7:15 am
Hi Vahram,
I apologize for the delay in getting back to you. This is a bit strange. Did you run the simulation directly from the example or are you making any changes to the simulation before running? It looks like the data in the middle portion of the waveguide is missing somehow. Is there any chance you set the span of that cell group to 0 um in the "EME setup" tab of the EME object. In any case, would you be able to share a screenshot of the EME setup tab? Thank you!
Amrita
