Ansys Learning Forum Forums Installation and Licensing Ansys Products Run ansys on multiple nodes Reply To: Run ansys on multiple nodes
MangeshANSYS
Since you already have an ARC cluster setup, then you can use Ansys RSM to run on multiple computers simply by launching Fluent through Workbench and setting solution to be sent to Ansys RSM using the number of cores you need to use.
please refer to these links below
Firstly configure RSM client
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/wb_rsm/rsm_clus_config.html
I am assuming you are familiar with starting workbench
add a desired Anslysis system
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/wb2_help/wb2h_addsys_drag.html
Submitting Solutions to Remote Solve Manager
 https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/wb2_help/wb2h_submit_solutions_rsm.htmlÂ
