Ansys Learning Forum Forums Discuss Simulation Fluids Serpentine cooling channel battery pack simulation temperature problem Reply To: Serpentine cooling channel battery pack simulation temperature problem
Kyu
Thank you for your reply Rob.
Then If I want the heat passes through solid to fluid, what option do I choose?
And you mean if there are interface zones, Is it impossible to heat entering to the fluid?: The battery cells generate heat and cool by aluminum channel and the inside the liquid water flows. Then, the water temperautre also change.Â
