Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Aerofoil and Cylinder with Rotating Wall Boundary Condition › Reply To: Aerofoil and Cylinder with Rotating Wall Boundary Condition
June 5, 2024 at 11:12 am
It should be OK to just set the cylinder wall motion, but check for odd effects at the ends.Â
Re the mesh, have a look at the various NACA examples. You need to avoid jumps in cell size but also if you're expecting flow separation to avoid high aspect ratio cells. So, inflation + flow separation isn't good.Â
