Ansys Learning Forum › Forums › Discuss Simulation › Fluids › AQWA, Actual and RAO based acceleration and response › Reply To: AQWA, Actual and RAO based acceleration and response
Thank you so much sxdu for the reply.
 I saw the documentation on RAO based and actual acceleration and motion parameters.
What is the major difference in the RAO based and actual acceleration? .
For an experimental validation which one should i consider? I had kept a sensor on the top of the model with moonpool. I used nodal displacement after creating a connection point and fixed point on the top.. The RAO based values are matching with the magnitude and actual shows the trend.
2. For a regular wave analysis in aqwa naut, why small irregularities are seen in the result'
This is from the user manual. Can i have more explanation on the high lighted part
NB. model is in moored condition with cables
