Ansys Learning Forum Forums Discuss Simulation Fluids Specify reactions in Fluent Reply To: Specify reactions in Fluent
So that step is rate limiting? In other words, if you don't get that bit right the rest of the results will be questionable. If you can find a production rate you could use a source term?
