Ansys Learning Forum Forums Discuss Simulation Fluids Specify reactions in Fluent Reply To: Specify reactions in Fluent
Ramesh Chandra Mishra
That is the issue. Its not clearly specified. The only reason I need to use this equation is because it gives atomic oxygen as a product which is used in the second equation to form ozone. If I ignore this equation, there is no source of "O" left. In literature they have only made an assumption that generation rate of O (FIRST EQUATION)=consumption rate of O(SECOND EQUATION)
