Ansys Learning Forum › Forums › Discuss Simulation › Photonics › HEAT: Sweeping over geometry gives wrong/same results › Reply To: HEAT: Sweeping over geometry gives wrong/same results
June 3, 2024 at 9:03 pm
Hi Leon,
I thought about it a little bit. Just to reiterate, if we don't lock the mesh, (which we should not do when the geomtery is changing) we can not create a combined dataset out of all the sweep results as the underlying grid will be different. The indivdual simulations will run, but we just can not combine the results.
- If you want to create a single dataset, what we can do is interpolate the results of the triangular mesh into a rectangular grid. Then create a combined dataset with these interpolated results.
- If you do not have any preferences about creating a single dataset, then we can individually access each result manually or using script, and save them as different datasets.
Let me know which one do you prefer and I can write and share an example script.
Amrita
