Ansys Learning Forum Forums Discuss Simulation Preprocessing 1e-6m meshing Reply To: 1e-6m meshing
If you do a quick hand calc how many cells are you going to get at that resolution?  If you're in Ansys Meshing there is a cap on surface facets to prevent the algorithms running away but I'm not sure what that value is now: it used to be around 100k cells.
